Corsas install
Old Sep 12, 2007 | 12:57 PM
rogan01's Avatar
rogan01
Default Corsas install
Decided to order the Corsa axlebacks - they will be installed by Midas.
How is the install? Straightforward? or are there any special tips, adjustmentsor "gotchas" I should look out for? I will be watching the install.
Thanks!
Old Sep 12, 2007 | 01:36 PM
LV51FER's Avatar
LV51FER
Default RE: Corsas install
It's straightforward. The Install is on the website at www,corsaperf.com. When I did mine, it was just a case of slight adjustments on the brackets and slight pulling on the hangers to get them sitting centrally. They're a bit heavy but they do what Corsa claim - nice note and no drone. Not as loud as you might wish though...
Old Sep 12, 2007 | 02:02 PM
MustangGT0405's Avatar
MustangGT0405
Dont waste the money to have these installed. If you have a socket wrench and a hour you are over qualified. I did mine in my driveway without jacking up the car. My only problem was it was like 100 degrees outside. I believe there is a "how to" stickied on here that tells you exactly what is required if you are unsure, it is basically a few bolts and a 2 hose clamps.
It makes a nice afternoon project with only a couple of busted knuckles.
Just as an FYI it takes a little while for mufflers to "break in" the sound right after install will change later on so dont be dissapointed if it doesnt sound right initially.
Good luck and enjoy it.
Old Sep 12, 2007 | 06:09 PM
Aziraphale's Avatar
Aziraphale
Unless you really really aren't allowed to touch anything mechanical, then it really is pretty easy to do yourself. Corsa's instructions are pretty good but if not, here are awesome ones.
https://mustangforums.com/m_3104526/tm.htm
Old Sep 12, 2007 | 06:16 PM
Jokeurmnd's Avatar
Jokeurmnd
Save yourself the money and do it yourself.I didn them myself and I will admit I'm not the best or even close but really its sooooo easy.
Old Sep 12, 2007 | 10:51 PM
Stkjock's Avatar
Stkjock
Retired Mod
the install... I watched did not do.... is very easy.... the hardest part is the alignment.....15-20 to install....30-40 aligning in my case
mtgldr
Feb 3, 2024 09:00 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
