Guys I REALLY need ur HELP
Old Sep 19, 2007 | 10:33 PM
Whiteflash454's Avatar
Whiteflash454
Default Guys I REALLY need ur HELP
Alright I need my fellow Mustang members preferably very knowledgable ones to help me otu here...I am purchasing a set of Stage 3 Crane Cams minimum RPM 2400 - 5900
Now I know I need a stall converter But i was hoping with your help you guys can help me chose the perfect matched up Stall..
Thanks,
much appreciated
Old Sep 20, 2007 | 09:36 AM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Guys I REALLY need ur HELP
you shouldnt be doing cams yet, there are plenty of other supporting mods you need for best performance out of those....LTs, new midpipe CMDPs
Old Sep 20, 2007 | 09:40 AM
ohnoesaz's Avatar
ohnoesaz
Yup, you need to do alot more things before cams. If you MUST have cams, maybe for the weird sound or something, then so be it. But stage 3?? I thought that was like supercharger/turbocharger grinds, I thought regular NA cars should stick to stage 1.
Anyways, someone on here will help with the converter question, but thats my opinion. Have fun either way!
Old Sep 20, 2007 | 10:54 AM
PLstang's Avatar
PLstang
ORIGINAL: howarmat
+1 I understand the supporting mods to be very important on the cams. Then agian I don't havecams so what do I know!
Perhaps you should look into some LT's and such first develope a repore with what ever shop your planning on using prior to going with cams. I have heard several people on here complain about the difficulty in tunnning them. You may want to make sure you have a comfort level with the shop doing the work prior to attacking a mod this size. Just my .02!
Old Sep 20, 2007 | 12:13 PM
thematrix's Avatar
thematrix
What are LT,s
Old Sep 20, 2007 | 12:33 PM
ratnacage's Avatar
ratnacage
Read this: http://www.kennedysdynotune.com/Torq...ter%20Tech.htm Seems like a pretty good primer on selecting a converter.
Stage 3 is good. Mine are similar to Comp's Stage 3 and they pull like a Mo Fo above 4000 rpm all the way to 7000 (though I try not to take it that high unless money's on the line ). The main difference between a blower cam and a NA cam is the duration/overlap, though I think blower cams tend to be a bit milder.
...and yes, you need long tube headers (LT's) to get the full benefit.
Old Sep 20, 2007 | 12:39 PM
sw07gt's Avatar
sw07gt
ORIGINAL: ratnacage
Those are some pretty good numbers you have. How much money have you put into performance?
Old Sep 20, 2007 | 08:54 PM
06tyrfryr's Avatar
06tyrfryr
I have the crower cams as well and pulls very hard at the higher rpm, but lost on my 60' so my n/a times remain the same, but have higher trap speeds, it seems to love the nos. headers and other mods made more of an improvement than the cams. tuning is the big problem with the cams, not many shops around have done them and received adequate gains to justify cost. I'm still experimenting with tune to try and get better mid range back.. my suggestion is do the cams last
Old Sep 20, 2007 | 09:10 PM
smythge's Avatar
smythge
Call crane and talk to the tech department they will recommend an appropriate stall converter. Not sure what you have for rearend gears but, that is something you're going to want to talk to them about as well. Abig cam with a high stall and 3.31s isn't going to be much fun on the low end. you're going to need 4.10s or higher
Old Sep 20, 2007 | 10:55 PM
Whiteflash454
I changed my mind about the cams, Im going to just go buy some Mac Longtubes and the prochamber
