tread direction?
Old Sep 20, 2007 | 09:30 AM
ink003's Avatar
ink003
Default tread direction?
hi guys
i have a confession to make - the treads on my rear tires are not facing the "correct" direction; in other words, the tires should be swapped so that the v-shape points forward to better facilitate water displacement. though i feel foolish, i must admit i didn't notice this until today when it was pointed out to me [8D]. the more i thought about it though, the more i wondered if this really matters much. besides, if i don't suffer "backwards" rear tires from time to time, i'll never be able to rotate my tires at all since the fronts are a different size. so.... should i switch the tires asap?
Old Sep 20, 2007 | 09:33 AM
marcuskeeler's Avatar
marcuskeeler
Default RE: tread direction?
The direction helps with water dispersal, nothing more. If it's wet there will be a noted difference in performance but otherwise I can't see a problem, other than being the victim of finger pointing and ridicule.
Old Sep 20, 2007 | 09:36 AM
ink003's Avatar
ink003
haha, that's for sure! i definitely felt like a dumbass but i'm glad that my instinct was correct: it shouldn't make much of a difference.
Old Sep 20, 2007 | 09:48 AM
frodaddi's Avatar
frodaddi
You don't need to remount the tires -just swap the left and right wheels and you are done.
Kevin.
Old Sep 20, 2007 | 09:59 AM
ink003's Avatar
ink003
yeah, i know i don't have to remount, i was just wondering about the necessity of swapping them. if it doesn't make much of a difference, i thought about just leaving them. i'm gonna want to rotate my tires eventually, so they would have to be "backwards" if i did. the fronts are not the same size, so i can't doa diagonal switch.
Old Sep 20, 2007 | 10:08 AM
frodaddi's Avatar
frodaddi
If it was me I would swap them. Easy to do and better safe than sorry. Our cars are tail-happy enough in wet conditions even under the best of circumstances.
$0.02,
Kevin.
offrdmania's Avatar
offrdmania
Rotating side to side is pointless as well, usually this is only done if you have a radial pull and you need to correct that. Because of your staggered fitment you cant rotate at all. Just wear out the tires and be done with it. Buy a new set at that time...
Old Sep 20, 2007 | 10:09 AM
ink003's Avatar
ink003
thanks for the advice, guys! i know what i'll be doing this afternoon
Old Sep 20, 2007 | 10:40 AM
banka87's Avatar
banka87
How often should we rotate our tires?
...Yea...feel free to flame me haha
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: frodaddi
$0.02,
Kevin.
+1
Water dipersal is the key here.
Backwards could actuall pull water
into the tire contact patch at high speeds
and heavy rain.[:@]
