Back Light Bulb
My center bulb on the rear right side of the car is burned out, how would I go about removing it and/or the assembly? Do I need a special bulb, or are they a sort of universal type? Thanks.
You might want to use some sealant around the studs when re-installing it.
Check your owners manual for the recommended bulb. I would replace all
of thebulbs with LongLife bulbs while you have it out. Back-up bulb included.
It is such a pain in the a$$ to remove and its possable to scratch your paint
pretty bad upon re-installation.
Is there a write up for sequential installation that shows the housing removal
sequence? Let me search for Tacos how-to..... FOUND IT:
https://mustangforums.com/m_3065383/tm.htm
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
