2 step
Old Sep 22, 2007 | 08:38 PM
06VistaBlueGT's Avatar
06VistaBlueGT
Default RE: 2 step
Hmmm, would be illegal in the class i run anyway. Can only run linelocks at the burnout so I imagine a trans brake is illegal too. If they determine that you're running linelocks on the starting line, you're DQ'd. Hmm, wonder if a 2 step is illegal?
Old Sep 22, 2007 | 08:39 PM
laserred02's Avatar
laserred02
Default RE: 2 step
ORIGINAL: Ford_Dude
unless I'm wrong they have trans brakes for manuals
I'll ask on a racing forum to be sure
why would you need a trans brake for a manual? the transbrake allows the driver to rev to a certain RPM without having the car creep forward in an automatic, and when the light hits they disengage and go forward. with a manual you have a clutch, depress the clutch setup a 2 step as the OP said, and then engage the clutch to take off.
Old Sep 22, 2007 | 08:40 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: 2 step
hum could be what class it is
you might want to be careful
you don't want to be dq'ed
is it a no electronics class or something
Old Sep 22, 2007 | 08:42 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: 2 step
ORIGINAL: laserred02
ORIGINAL: Ford_Dude
ok I think I'm wrong
I asked over on a track's forum so I'll find out more
Old Sep 22, 2007 | 08:48 PM
06VistaBlueGT
Default RE: 2 step
It's a street legal class. Typically they run it like the foot brake class which is no electronics. Wondering how they would prove I have a 2 step since itwould bepart of the tune? My RPM's are so high at the line it would sound like I'm bouncing off the rev limiter. Worst they could do is DQ me and tell me to remove it before I come back.
Old Sep 22, 2007 | 08:51 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: 2 step
ya but if your DQ'd early on then you miss out on the fun that time
I would check but it sounds like a 2 step would be a dq
Old Sep 22, 2007 | 08:55 PM
06VistaBlueGT
Default RE: 2 step
They typically give you a warning first. They had to tell 15 people friday night that they'd let them run that night but don't come back until you have fixed the issue. There was a Kenne Bell GT500 running 11.40's. Told him not to come back until he had a full cage and firesuit.
Most others were for nitrous. Big no no in street legal.
Old Sep 22, 2007 | 08:58 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: 2 step
for the 500 I would think they did that for NHRA safty rules and the rules of the comp class would be enforced a little differant
I may be wrong
Old Sep 22, 2007 | 09:09 PM
06VistaBlueGT
Default RE: 2 step
Yes, they are an IHRA sanctioned track (Quaker City Raceway). The rules state any hard roofed car that runs 11.49 and quicker must have a roll cage and the driver must have proper safety equipment.
Old Sep 22, 2007 | 09:16 PM
06tyrfryr's Avatar
06tyrfryr
Default RE: 2 step
trans brake is not available for mt's. usually a line lock is acceptable for mt type cars and not on autos for staging
