Some supercharger questions...
Alright, so as I type this there is a sexy polished Whipple HO sitting in a box in my garage. Right next to it is a Speed of Sound triple pod A-pillar frame, and three beautiful Autometer Nexus gauges...Don't ask how much it cost, let's just say those professional school loans went to good use, haha!
Any help with these issues would be great (not that it is going to sway me from installing it, just curious):
1.) The GT currently has SLP Loudmouths on, does the S/C require a better exhaust setup to breath easier? I don't want to blow up the engine just because I didn't have enough air flow...
2.) Has anyone put a rider policy on their insurance to cover theft/damage to the S/C? How much extra a month does it cost to insure the extra 6-7k for the engine?
3.) When in the boost range...how much is gas mileage affected?
4.) Anybody know a reputable tuner in AZ that won't charge an arm and a leg? AMP in PHX wanted like $900-$1000, ouch.
5.) Any other issues with install of any of the gauges or S/C I should be aware of?
Thanks in advance.
By the by...I will be selling my Midwest Auto plenum cover, it's Tungsten Gray and flawless. Also I have a brand new, never used, never painted, never attached Cervinis C-series body kit if anyone is interested. I can't afford paint so it has to go, or sit in my storage unit until I get out of pharmacy school in 4 yrs. If interested hit me up.
Thanks in advance.
RE: Some supercharger questions...
1)SLPS will be fine, if you want a bit more power go for some long tubes.
2)Not sure about the insurance but if you find out let me know!
3)You will actually get much better milage at cruise speeds, but of course when you pounding it you'll lose a bit, but youroverall MPG will remain right about the same as now.
4)Custom Dyno tunes are very expensive usually between $600-$800. Thats the last thing I would be cheap about, as it is by far the most important factor when heavily modding your car.
5)Did you get Wide Band gauge? if not, I recomend it.
Good luck and keep us all posted!
Yep, the gauges I got, thanks to the recommendations of MF members, was the boost vac, fuel pressure and of course, the digital wide band A/F. I definately want to protect my investment!
for the insurance, i dunno if its different in the states, but us lucky canadians dont have to do anything but get a new quote done by a certified mechanic for the replacement value, and if our car is under $50k we pay the same insurance.
I am pretty sure it would be different with my insurance company at least. My baby was recently broken into and my DVD player, ipod, music, etc was stolen. My insurance company told me that because I didn't have the extra coverage, they wouldn't pay for these items. They did, however, cut me a check for $1000 for the dvd player, but they just said that this wasthe max that the company offeredfor electronics...oh well...I let you guys know what they'll charge me for the S/C.
ORIGINAL: RideCRF450
When you go to install the dual fuel pumps make sure the float isperpendicular tothe passenger side of the car, that should put the large arrow on the top perpendicular to the drivers side. Here's a tip, tire a wire to the fuel crossover tube that you need to reconnect to the new fuel pump. The first time I put the pumps in I couldn't reach the damn thing so had to pull the pumps back out. You can hook it up before putting the pumps in, but it just makes it harder to fit the pumps through the hole. go slow and push all the tubing inward as you lower it. Don't forget to connect that crossover tube.
I almost ran off the road trying to watch my boost gauge. Things happen fast at WOT.
