Interior door handle Question
I have a non-IUP Ebony interior, and wanted to spruce up the doors.Are there specific part #'s for the IUP door handles (silver in color) for a Ebony interior? I have looked online and can't pin downanything. Any ideas?
This might help i just finished installing the interior door handles on mine i got them today see if this what you are looking for #5R3Z-6322601-AAC & 5R3Z-6322600-AAC is the black housing with the silver handle.
07GT4.6,
Iran the part #'s and they look like they are right on. Was the installation difficult? Do the housings pop out or do you have to remove the entire door panel to change them. Thank for the quick response!!
Is no rocket scince but they do take a little while if you do not remove the panels you need a panel puller,a pick,a torks bit and tape,remove the screw cover with the pick tape arround the handle and carefully pry on the housing remove the power lock plug and the door latch cable be carefull with the power lock switch i might come appart mine did but i put it together again.If you want to make it easy on yourself just remove the panel i did not remove mine cause the car is covered and me being lazy did not want to take the car cover off and i wanted to see the handles on they look real good gud luck.ill try to take some pics if it helps.
Thanks again for the info. I have taken off my right door panel before and I will probably go that route since I don't want to scratch up the panel. Daniel06GT, www.newfordparts.com sells OEM parts direct. I just ordered my door handles from them. I too would be curious as to the leather dash panel part#.
Dragonus18
Sep 9, 2015 01:21 AM
