Tutorial: Custom Antenna Delete
Old Oct 13, 2007 | 05:20 PM
  #31
odiaz's Avatar
odiaz
Default RE: Tutorial: Custom Antenna Delete
My body shop only charged $175. They welded the holes closed and painted the fender, painted the mirrors, my lower grille and my CDC spoiler. The color match was perfect. I used a Metra amplified antenna and mounted it on the windshield and the reception is even better then with the original antenna.
Here is my write up and some pictures:
http://www.cherod.com/mustang/HowTo/...a%20Delete.htm
Old Oct 14, 2007 | 04:36 AM
  #32
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Great job I was wondering how you did this?!
Old Oct 14, 2007 | 11:33 AM
  #33
pascal's Avatar
pascal
S197 Section Modder-ator
Congrats odiaz!
Best antenna mod so far.
Me like
Old Oct 14, 2007 | 12:10 PM
  #34
2007GT/CS's Avatar
2007GT/CS
ORIGINAL: odiaz
+1. I followed Odiaz' advice when I had mine done. Mirrors, antenna, and I also had the washer nozzles removed.
However, critical parts of that process aren't usually DIY. Props to Nels for a great alternative!
Old Oct 14, 2007 | 12:26 PM
  #35
CroDalmatinac's Avatar
CroDalmatinac
ORIGINAL: 2007GT/CS
ORIGINAL: odiaz
How do you wash your windows than?
Old Oct 14, 2007 | 12:31 PM
  #36
2007GT/CS's Avatar
2007GT/CS
ORIGINAL: CroDalmatinac
ORIGINAL: 2007GT/CS
ORIGINAL: odiaz
I installed a relocation kit that places the nozzles on the back side of the wiper arms. Out of sight and work well.
Old Oct 14, 2007 | 01:27 PM
  #37
CroDalmatinac
ORIGINAL: 2007GT/CS
ORIGINAL: 2007GT/CS
ORIGINAL: odiaz
Where did you get the kit? I am going for the clean look so...yea haha
Old Oct 14, 2007 | 02:57 PM
  #38
mlcrycc's Avatar
mlcrycc
ORIGINAL: 2007GT/CS
ORIGINAL: 2007GT/CS
ORIGINAL: odiaz
Here's one, but some of the reviews I have read are not so favorable.......
http://www.classicdesignconcepts.com...splay/685.html
Old Oct 14, 2007 | 05:32 PM
  #39
2007GT/CS's Avatar
2007GT/CS
That's exactly the kit. Toughest part is pulling the wiper arms. Instructions say you can 'tap' them. I actually used a battery post puller (looks like a small gear puller) to do mine.
Other than that it is just pushing in connectors, routing small rubber lines and attaching things to the underside of the wiper arms with 2 way tape.
Easy.
Old Nov 8, 2007 | 11:19 AM
  #40
luckydawg003's Avatar
luckydawg003
how did you get the antenna wire off the metal base of the plastic piece you painted? I need to remove my fender and can't get the stuped antenna orange wire off. My antenna is like welded to the big metal base thing. Tried using vice grips to get it off but just scraped the sh*t out of it. Also you should have said that the first plastic piece has two indentions in the front and rear of it..I jacked mine up bad, now I have to buy a new one.
