Keyless entry keypad installed
Old Oct 12, 2007 | 10:42 AM
  #61
ArcticFrog's Avatar
ArcticFrog
Default RE: Keyless entry keypad installed
ORIGINAL: ArcticFrog
ORIGINAL: howarmat
here you are for 74+ shipping
http://fparts.autowebaccessories.com...2a57b699b929d1
Thank you howarmat! I love the 'behind the fuel door' idea, that's where mine is going.
UPDATE to this link: I ordered a keypad from here and received it today. It is NOT the smaller style keypad, it's the larger one. The stock number on their website is for the smaller keypad but they sent out a bigger one. I called and their story is that their Ford guy told them there was no difference and the part number on the box (for the larger pad)had been marked out with a sharpie and the new smaller keypad part number was written on. They were very apologetic and said they were going to pull the item from their website because they'd been having some other complaints/issues with this item (ya think?).
So long story short, don't order it from here unless you're fine with having the larger pad. I wasn't. They're issuing a calltag to pick it up and giving me a full refund, shipping included.
Old Oct 12, 2007 | 11:13 AM
  #62
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: howarmat
Try Steeda for $99.
http://www.steeda.com/products/s197_...ccessories.php
Old Oct 12, 2007 | 12:47 PM
  #63
howarmat's Avatar
howarmat
s197 Junkie
I got mine, its the same size as what partsbill has for his....why do you think its suppose to be smaller design now?
Old Oct 12, 2007 | 01:10 PM
  #64
partsbill's Avatar
partsbill
7L2Z 14A626 BA is the part number for the new design.
Keyless Entry Keypad
Part Number: 7L2Z-14A626-BA
MSRP: $85.00
Conveniently unlock your vehicle without your key or keyless entry remote. No wiring necessary – programmable, backlit keypad tunes to the same frequency as your transmitter. No-drill installation. Comes with two covers: one is primed (paint to match); the other has a black textured finish. For vehicles equipped with factory remote keyless entry.
Old Oct 15, 2007 | 02:17 PM
  #65
ArcticFrog's Avatar
ArcticFrog
ORIGINAL: howarmat
autoweb accessories listing is here:
http://fparts.autowebaccessories.com...od831_8391.php
The problem is that they list the new/smaller keypad part number with a pic of the larger/old design of the keypad. My bad for ordering based on the part number without confirming but their bad for listing a part number that does not match the pic they show of the item for sale.
The part number listed ontheir website is 7L2Z-14A626-BA which matches a keypad shown at this link:
http://www.fordaccessoriesstore.com/...ries.asp?id=38
The keypad that was sent to me is part number 3L2Z-14A626-AA and is the keypad shown at this link:
http://www.fordaccessoriesstore.com/...amp;detail=yes
Old Oct 15, 2007 | 05:40 PM
  #66
howarmat's Avatar
howarmat
s197 Junkie
ahh, so the one that partsbill has is the old design, i was thinking that was the new design....my bad...hmm maybe i will return mine, cause that one fits into the gas compartment!
Old Oct 29, 2007 | 08:49 AM
  #67
oldschoolv6's Avatar
oldschoolv6
Hi new member here I just received this keyless pad (old Style) as a gift for my 2007 V6, and I like the under the gas cap location. The only question I have is the programming procedures only list up to 2004 Mustang, which method do you use to program a 2007?
Thanks for the help
Old Oct 29, 2007 | 11:20 AM
  #68
partsbill's Avatar
partsbill
[align=left]All Other Vehicles [/align][align=left]NOTE: If your vehicle is equipped with Integrated Keyhead Transmitters IKTs, you do not need all the IKTs to program the RF keypad to your vehicle. [/align][align=left]9. Make sure that you have all of the Fobs and RF keypads for this vehicle. [/align][align=left]10. Unlock your vehicle electronically with the Fob or door unlock button. [/align][align=left]11. Put a key in the ignition. [/align][align=left]12. Turn the key from the OFF position to RUN (not START) position eight times within 10 seconds with the eighth turn ending in the RUN position. The doors will lock, and then unlock, to confirm the vehicle is in programming mode. [/align][align=left]13. Within 20 seconds of completing the previous step, press any button on Fob 1, if equipped. [/align][align=left]The doors will lock, and then unlock, to confirm that the Fob has been programmed. [/align][align=left]14. Within 20 seconds of completing the previous step, press any button on Fob 2, if equipped. [/align][align=left]The doors will lock, and then unlock, to confirm that the Fob has been programmed [/align][align=left]15. Within 20 seconds of completing the previous step, press the 7/8 and 9/0 buttons simultaneously on the RF keypad 1. [/align][align=left]The doors will lock, and then unlock, to confirm that the RF keypad has been programmed. [/align][align=left]Repeat this step if more than one RF keypad is used. [/align][align=left]16. After all remote entry transmitters have been programmed, turn the ignition to the OFF position.[/align][align=left]The doors will lock, and then unlock, to confirm that the vehicle has exited programming mode.[/align][align=left]it's easier to program your keypad before you install.[/align]
Old Oct 29, 2007 | 11:34 AM
  #69
pnandy's Avatar
pnandy
what if you have 6 fobs. dead serious i got as much outta the dealer as possible when buying the car
Old Oct 29, 2007 | 11:50 AM
  #70
partsbill's Avatar
partsbill
shop manual says you can program up to 8 keys, I assume you would be able to program up to eight key fobs, check your owners manual, I believe it tells you how many can be program, or just try it.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
