few ?? about gears
ORIGINAL: kirax105strike
1. what is the difference between the 4.10 and the 3.73s
2. what is gained by switchout my stock gears
3. and last (newb question) whats TLOK
2. better accelleration (assuming you`re going numerically "higher"
3. limited slip differential
1. 9.92% difference in spin rate means that at a given rpm of the motor you will go ~10% slower (or need 10% more rpm to go the same speed).
2.The gearing difference also means that you put 10% more torque at the ground at any given speed. Your horsepower will not be affected much, if at all (often goes down a couple at the wheels) because the rate at which the torque increases with time does not really change. In layman's terms, you will feel a MUCH harder pull when WOT, that many describe as "fake 50 horsepower" because it will improve acceleration and track times in a similar manner.
3. TLOK is the Ford-specific name for a limited slip differential. It is designed to put equal power to each wheel under heavy loads by locking in the rear axle.
KingRando
Oct 2, 2015 08:06 AM
junior04
Sep 28, 2015 10:53 AM
