drag radials or 4.10s
RE: drag radials or 4.10s
ORIGINAL: nineinchnail1024
For the cost of 4.10s and installation, I would prefer a pair of spare rims and M/T ET Streets. Brenspeed sells a good package.
Most shops will do FRPP gears for ~500, some as low as 400, some as much as 600 installed including parts.
No one in the general public is gonna get a set of ET Streets for much less than that, if at all. A set of cheap used racing wheels is going to cost another 200-300, and double that for skinnies and tire up front.
...now you can go down the quarter mile, and maybe drive it to the track if you don't get a ticket for it on the way there...plus you have no 4.10s.
ORIGINAL: jwbrown21
If you only had enough to do one of these mods.. what would you do? and why?
ORIGINAL: 28HopUp
It truly depends on why you are asking. If you don't intend to hit the track often, then gears would be a better choice. If I had a GT with 3.55's like you, I would go with DR's. Having a pair of meaty DR's out back is more than a performance booster, it makes the car look better (well, when the rims match the front). I've beaten S197 GT's at the track with my N/A 4.0L V6 because all they could do was sit & spin.
ORIGINAL: jwbrown21
