Super Charger Done... Now What??
RE: Super Charger Done... Now What??
I would upgrade the brakes pads and aftermarket slottedrotors first(about 4-5 hundred) and then the LCAs, UCA and relocation brackets. A rear girdle for the diff to help the diff bearings survive would also be a most welcome addition. Lowering springs, struts/shocks would then be added, but not before the aforementioned, then perhaps the a one piece driveshaft/clutch/wheels/tires last. If you add a bunch of go you're gonna need some whoa firstIMO.
Building the rear suspension and adding DR's gave me .6-.7 off my ET. The BMR re-locate brackets benifit those that have lowered their car themost. If you have an S/C and haven't done the proper suspension mods, that should be the first thing. Then brakes and other things as they break.
ORIGINAL: DeStonn
relocation brackets let the car 'squat' for added traction.
In that they keep the car from squatting; as the rear end squats the axle raises up losing grip.
The LCAs push up on the body forcing the axle to the pavement.
Look for CrazyAl’s posts he seems to know his stuff on this subject
