Car died Failsafe mode ????? HELP throwing many codes
#23
RE: Car died Failsafe mode ????? HELP
you have a problem with either the throttle body, or the TP sensor on the pedal. have you done the "pedal mod"? if so, i'd get a diff. pedal sensor assembly. if not. a trip to the dealer is in order..
the p2106, p2135 codes mean that the positions derived from the TP sensors are off by a set amount.
the p151a is a intake manifold runner controller performance.circuit open, binding linkage, damaged IMRC actuator.
if you want to diag this yourself, clear the codes, run the car, and determine the first code that sets, that problem is likely covering the others. lets not worry about evap for now.
#24
I would like to do this myself. I highly doubt the dealer is going to do warranty work on a car with nitrous. I will reset the codes and see what pops up first.
#27
A couple of things I would consider checking...
1. Make sure your MAF sensor is pointing the right way in the housing.
2. Where you tapped the signal for the WOT switch on the nitrous kit, make sure the connection is solid.
