Wheel well sub boxes?
Old Oct 14, 2007 | 07:42 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Wheel well sub boxes?
My amp in installed above under the rear dash in between the 5x7s......you cant tell its there unless you stick your head in the trunk and look up. Takes no additional space so the install looks great!
Old Oct 14, 2007 | 07:45 PM
alloutt's Avatar
alloutt
how come people don't put subs on both sides?
Old Oct 14, 2007 | 07:46 PM
drbobvs's Avatar
drbobvs
The MTX thunderform can come with an amp built in but you have to remove it everytime you want to make an adjustment. That's why i got my own amp and have the controller in the center console. I'm not worried about it being in the middle of the trunk, I've had stuff on top of it for 2 years now and no issues. In the vert the trunk mat is one piece of carpet glued to 2 pieces of hardboard. The 2 pieces of hardboard areattached via metal plates. I removed the plates and attached the 2 pieces back together with a piano hinge. Now i have acces to the spare and stuff without disturbing the amp.
Old Oct 14, 2007 | 07:48 PM
Ford_Dude's Avatar
Ford_Dude
ORIGINAL: alloutt
+1
Old Oct 14, 2007 | 07:50 PM
2007Grabber's Avatar
2007Grabber
There is only one place to get a drivers side box and they don't come with the subs. They look good, but would end up being a very precey system to have.
http://cgi.ebay.com/05-06-07-FORD-MU...QQcmdZViewItem
Old Oct 14, 2007 | 08:02 PM
nonstopred's Avatar
nonstopred
ORIGINAL: howarmat
pics of this set up would be great to see. thanx
Also, whats the deal with running the power cable from the battery back? Do you need resistors?
Old Oct 14, 2007 | 08:08 PM
howarmat's Avatar
howarmat
s197 Junkie
The JL 12 that I have is plenty of bass....its not going to win any contests but its plenty for my DD stang.....
Old Oct 14, 2007 | 08:10 PM
howarmat's Avatar
howarmat
s197 Junkie
yes you have to power you amp from the battery, and its not a resistor is a capacitor....i will run out and take a few pics since....i was watching 28 days/weeks later and didnt want to pause it...
Old Oct 14, 2007 | 08:24 PM
nonstopred's Avatar
nonstopred
whoops
what does the capacitor do?
Old Oct 14, 2007 | 08:30 PM
Ford_Dude's Avatar
Ford_Dude
ORIGINAL: nonstopred
whoops
the simple explanation is even out the highs and lows voltage wise and that lowers the strain on the (charging system)
