Wheel size
I am looking at getting some new rims and tires. I was looking at some package deals and one site recommend I go with 18x9.5 with 275/35/18 tires all the way around are these too wide for the front? Just looking for suggestions. these are the rims I am looking at
http://cruizinconceptswholesale.com/...2D18X95&cat=25
I'm sorry but a 275/35/18 is a very small wheel diameter than stock. Your speedo will be off quite a bit unless you have a handheld to correct. You will also have a much larger wheel well gap.
Your stock wheel diameter is 27.1"
Your proposed wheel tire combo is 24.6" which is a difference of about 10%
I wouldn't do it.
I wouldn't do it.
a 35 series side wall is to small for 18 inch whells, heres a pic of my 305/35r18 drag radial 18x10 in bak,not happy with sidewall size american muscle should stock 40 or 45 series. once i burn these up ill be goin for a 40 or 45
ORIGINAL: NyFordTech
a 35 series side wall is to small for 18 inch whells, heres a pic of my 305/35r18 drag radial 18x10 in bak, not happy with sidewall size american muscle should stock 40 or 45 series. once i burn these up ill be goin for a 40 or 45
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
