differential fluid change
Old Oct 22, 2007 | 08:51 PM
Dwisforme05's Avatar
Dwisforme05
Default differential fluid change
anyone done this? something i can do at home? i have 51K on my car and i think its time to change it. anyone know how or done it?
Old Oct 22, 2007 | 08:56 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: differential fluid change
stock diff cover has to be unbolted i think and then bolt up with new gasket and then fill
Old Oct 22, 2007 | 10:09 PM
Dwisforme05
i thought there was a drain on it?
Old Oct 22, 2007 | 10:14 PM
2007GT/CS's Avatar
2007GT/CS
Not on the stock cover. You need an aftermarket cover/girdle.
Old Oct 22, 2007 | 11:09 PM
marcuskeeler's Avatar
marcuskeeler
Was wondering about this myself as the diff is starting to groan on tight turns. I know there's a TSB out on the clutch packs but figure it's not a big issue although an oil change couldn't hurt.
Old Oct 23, 2007 | 12:35 AM
ohnoesaz's Avatar
ohnoesaz
Its really easy, do it.
Just loosen the little black bolts around the cover, then pry off cover. Fluid will drain out.
Use silicon sealant on old cover, or buy a new one, and replace it. They say let it sit 6 hours... I did 1 hour. Then locate fill plug and fill from top. They say use a pump or something, but I was able to angle the bottles and just pour them straight in. I used Mobil 1 75-140 and generic friction modifier. MAKE SURE YOU USE FRICTION MODIFIER, THE END. No questions asked. You need it.
Fill up to fill hole, but make sure you compensate for the car possibly being angled from being jacked up. I did mine without jacking car up.
Have fun its worth it, wait till you see the metal shavings that come out in the old fluid.
Old Oct 23, 2007 | 01:36 AM
my first mustang's Avatar
my first mustang
You can also use a suction pump if you dont want to remove the cover. Available at any good auto-parts store. Just make sure to drive the car a few miles to warm up the oil. Removing the cover is best BUT if first few thousand miles on car this way is much easier&faster(plus no chance of a leak).Worked at a dealership for many yearsand we always changed the rear fluid this way at 1st engine oil change. 5 min. job with lift.
Old Oct 23, 2007 | 04:46 AM
sleeper2's Avatar
sleeper2
Step 1:
Step 2:
Sleeper2
Old Oct 23, 2007 | 07:31 AM
GidyupGo's Avatar
GidyupGo
You don't want to "pry" off the cover. Could mess up the mating surface. I use a block of wood and a hammer. Just smack the side of the cover and the jar will break the seal of the old gasket.
mtgldr
Feb 3, 2024 09:00 PM
LivingInThePast
Sep 16, 2015 12:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
