Sponsored by:
Sponsored by:
is this hard to install?
Old 10-30-2007, 11:47 PM
juni0r
juni0r's Avatar
Default is this hard to install?
I have 2007 Mustang GT. It is a standard carbut I do not like the stock shift.It does not matter where I sit my seatI stillmust reach a long way for fifth gear and toreverse.Also Imiss third shift sometimes.
Istheshifter hard to put on the car? Could I do it myself? I have basic tools saw how to install the Hurst shifter on this site. This looks different to the Hurst model and others. I do not have spare money. Willthis workfor my car and can I put it onmyself?
http://cgi.ebay.ca/2005-and-up-Musta...QQcmdZViewItem
juni0r is offline
Old 10-30-2007, 11:51 PM
Black121
Black121's Avatar
Default RE: is this hard to install?
I think it all depends on how confident you are in your own mechanical ability. I'm no mechanic but understand machinery enough to tackle most tasks on my own. I would find that specific job if anything just time consuming cause I'd make sure I was doing it right. I don't personally think it would be hard. Good luck!
Black121 is offline
Old 10-30-2007, 11:54 PM
rshamekh
rshamekh's Avatar
https://mustangforums.com/m_3000094/tm.htm
Decide for your self if you can do it on not.
But why not go with a Hurst or MGW?
rshamekh is offline
Old 10-31-2007, 01:06 AM
Bluestar
Bluestar's Avatar
The install of the shifter isn't too hard. But if you don't think you can handle it, I don't think it would be too costly to have a Shop do it for you. As far as the Shifter in question, I don't know of anyone that has that particular one. Most guys get the Hurst, or MGW.
Bluestar is offline
Old 10-31-2007, 01:09 AM
SRT_what
SRT_what's Avatar
I think I swapped my old one for my new one with the car on jackstands in my garage in about a half-hour. That sounds like a run-on sentence.
SRT_what is offline
Old 10-31-2007, 05:15 AM
sleeper2
sleeper2's Avatar
Mechanically it is very straight forward. If you gather up the various "shifter install" write-ups floating around you will get a good idea of what's involved.The most important thing is knowinghow to work under your raised car safely.
Sleeper2
sleeper2 is offline
Old 10-31-2007, 09:49 AM
06Redfire3V
06Redfire3V's Avatar
i'm only 17 and have never done anything to my car and i installed it with help from a buddy so if i could i believe u can.. on a scale of 1-10 i give it a 3 just because its hard to put the new shifter in the hole it takes some time and some good angles
06Redfire3V is offline
Old 10-31-2007, 10:04 AM
cavediver
cavediver's Avatar
As for the shifter in question, B&M has always made somepretty darn good performance equipment. Although I have not seen this particular B&M model, I recently installed one of their shiftersin my friends '33 Ford coupe.It was a ratchet design for a GM Turbo autoand the fit and finish was excellent, it installed very easy and worked great. I have no idea how well this short throw Mustang shifter would work but based on my experience it should be just fine.
cavediver is offline
Old 10-31-2007, 10:30 AM
DarkFireGT
DarkFireGT's Avatar
The hardest part is getting the shifter through the hole. It's a piece of cake. And believe me, I am no mechanic.
DarkFireGT is offline
Old 10-31-2007, 10:41 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: DarkFireGT
+1
After the OEM is wrangled out and the new one
is in the hole its pretty simple after that. Take
pics of the OEM linkage before removal so you
dont get it installed on the wrong side of the B&M..
157dB is offline
Quick Reply: is this hard to install?
