Can someone explaing LCA etc?
Old Nov 3, 2007 | 07:33 PM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
Default Can someone explaing LCA etc?
I keep reading of people replacing the lower control arm or relocating it etc. Some adjustable some arent. Anyone able to give me a quick explanation with advantages and whats the best to buy if you are on budget. I appreciate it. No luck with search [&:]
Old Nov 3, 2007 | 07:39 PM
DeStonn's Avatar
DeStonn
Default RE: Can someone explaing LCA etc?
https://mustangforums.com/m_2727670/tm.htm here is a link from a guy who is pretty knowledgeable
Old Nov 3, 2007 | 07:40 PM
5SPD07GT's Avatar
5SPD07GT
ok, thanks. I'll read it. I left out UCAs too
Old Nov 3, 2007 | 07:44 PM
5SPD07GT's Avatar
5SPD07GT
ok, good info there. I read the whole write up. It basically improves your traction/launch. Now what about UCAs? Back to LCAs, is this what i'd want... http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
Old Nov 3, 2007 | 07:51 PM
Rubrignitz's Avatar
Rubrignitz
Yes, improves your traction/launch. This is only acheived with the relocation brakets which changes the angle of your LCA's. Just replacing your LCA's with aftermarket will only be lighter. However, if you're going to lower your car, getting adjustable LCA's (or an adjustable UCA) will allow you to adjust your pinion angle. Here is a good vid of BMR fabs LCA "anti wheel hop" kit and how it works to improve your traction:
http://www.nmratv.com/index.php?stre...amp;playlist=1
Old Nov 3, 2007 | 07:56 PM
5SPD07GT's Avatar
5SPD07GT
thanks! I have the roush rear springs only as far as lowering goes. So basically a relocation bracket would be all i'd want if i'm on a budget?
Old Nov 3, 2007 | 08:01 PM
Ford_Dude's Avatar
Ford_Dude
go to this link and scroll down
http://www.bmrfabrication.com/2005MustangPACKAGES.htm
only the base anti-hop kit includes the bracket the level 1, 2, 3 don't
Old Nov 3, 2007 | 08:04 PM
5SPD07GT's Avatar
5SPD07GT
but i can just buy the brackets with the arms, correct?
Old Nov 3, 2007 | 08:09 PM
Ford_Dude's Avatar
Ford_Dude
yes
the link I posted goes to the packages section of BMR's page
from looking at the packages you can tell what comes in the packages to helpplan you future mods
Old Nov 3, 2007 | 08:10 PM
Ford_Dude's Avatar
Ford_Dude
so if after the brackets you want more you can see what else BMR suggests
