Stupid oil mistake...
Old Nov 4, 2007 | 02:37 PM
goharv's Avatar
goharv
Default Stupid oil mistake...
Had to do my 18,000 mile change today, so I ran down to Advanced Auto and picked up some Mobil 1 Syn oil and a MotoCraft filter. Well I put it in and then realized that I was thinking of my other car when I grabbed the oil. I put in 5w-30 instead of 5w-20. If I remember right the second number is the high temp viscosity so I am thinking I will be fine. I live in central TN so the temps are only up in the 60's now and in the 30's at night. Should I drop out the oil, or am I fine for another 3k until my next change? thanks
ps. Tried to search, but the function isn't working too good right now.
Old Nov 4, 2007 | 02:45 PM
Bmr4life's Avatar
Bmr4life
Default RE: Stupid oil mistake...
Switch it back out, thats only about $35 in oil.
Old Nov 4, 2007 | 02:47 PM
thewarmachine's Avatar
thewarmachine
You're fine. If you're worried, just change it out after about 5000 miles. Engines are robust, and a small change like that makes no difference.
Old Nov 4, 2007 | 02:49 PM
Ford_Dude's Avatar
Ford_Dude
switch it out
at operating temp the oil won't be able to reach all the little places that need oil
Nuke's Avatar
Nuke
Too bad you can't do a "transfusion" to your other car...
Not too sure about running the 5W-30 in the Stang... I've heard different stories. Change it if you want the piece-of-mind.
Old Nov 4, 2007 | 03:01 PM
hammeron's Avatar
hammeron
might as well make this a poll
flip a coin
heads, it'll be fine
tails, better switch it out or your engine will blow
Old Nov 4, 2007 | 03:02 PM
04 40th gt's Avatar
04 40th gt
I think you will be fine. I just did an oil change on mine today, and the oil that came out was 5w-30. I used it last cause it was on sale. 5x-20 was on sale this time. I had no issues. The engine ran fine.
Old Nov 4, 2007 | 03:07 PM
Nuke's Avatar
Nuke
ORIGINAL: hammeron
...flip a coin
Knowing the forum, the coin will land on it's side...
Old Nov 4, 2007 | 03:20 PM
Ford_Dude's Avatar
Ford_Dude
ORIGINAL: Nuke
ORIGINAL: hammeron
...flip a coin
no I think the coin would split in two and both would be on their side and they'd roll off lol
Old Nov 4, 2007 | 03:23 PM
hammeron's Avatar
hammeron
ORIGINAL: Ford_Dude
ORIGINAL: Nuke
ORIGINAL: hammeron
...flip a coin
