ok so i got the 8-inch shorty antenna from american muscle and in the package was the antenna, 3 different size screws and an extender or something.. ive tried every possible combination of screws and i cant get it to fit on my car.. ill have a picture in a little bit of all that i go
I put my 14" in, and I know i didnt use the extender, and im pretty sure i used the rightmost screw in your picture with the short end with the thicker threads going into the antenna, and the longer end going into the base, when i get back in town on fri i can check for you for sure if noone else has answered yet, but it did take a bit of messing around with it to get it on there just right
hmm, i will have to double check for you when i get home on fri then, tho I am reasonably sure that i did not use the leftmost one you have there which leaves only the middle one to try
I bought the same one, from the same place.....45 seconds after I opened the package it was on, lock-tite and all. Sorry I don't recall which, if any of the screws I used. It's not like you're putting one of these on....
I have the exact same one and i used one of the adapters.. When i go home at lunch i'll check and let you know witch one i used just hang tigh for an hour or so..
