Question About Injectors (39) and Turbo sizing.
Around what hp do the 39lb injectors start to max out on our cars? Also does any1 have a dyno sheet of a 60mm vs a 68mm. What is the real efficiency range for the 60mm is?
Andrew
Andrew
60-1 is supposed to max out about 500 rwhp.
I think thats just about what Justin (VMP) said the 39 psi Injectors max at as well.
This assumes you have enough pump to hold 39 psi + 12 psi.
I think that turbo is really happiest below 10 psi.
Over 10 psi you really need to consider a bigger turbo.
