PROCHARGER HELP!!!
Old Nov 27, 2007 | 04:15 PM
Thurman's Avatar
Thurman
Default PROCHARGER HELP!!!
I have my 07 gt apart and and I think I have a 05 kit. Does this matter?
D trim if it matters.
Thanks,
Thurman
Old Nov 27, 2007 | 04:43 PM
Black05StangGT's Avatar
Black05StangGT
Default RE: PROCHARGER HELP!!!
I was under the impression that the 05 and 07 kits were different, but I could be wrong though, I'm sure someone will chime in...
Old Nov 27, 2007 | 05:42 PM
ANBAUTO's Avatar
ANBAUTO
the kits for the 07 are slightly differnt from the 05/06 models. I believe some of the pipes are what change
Old Nov 27, 2007 | 05:51 PM
A1SALEEN's Avatar
A1SALEEN
call procharger and ask them .... i'm not sure what would be different
Old Nov 27, 2007 | 07:15 PM
06tyrfryr's Avatar
06tyrfryr
I was also under the impression that something is different on the 07s, but cant recall what it is.
Old Nov 27, 2007 | 07:24 PM
moosestang's Avatar
moosestang
The thermostat housing is different on the 07+, but not sure if that matters with a procharger.
The 07's have the thermostat mounted in the coolant crossover tube, but on the 05-06 it sits about where your procharger will sit, out infront of the engine in the coolant hose.
Old Nov 27, 2007 | 07:45 PM
Thurman's Avatar
Thurman
Thanks guys. Moostang you are correct. And I can still use this kit. Proceeding with the install. I will post when done.
Thurman
articman
Jun 21, 2018 11:45 PM
Granatelli Sales
Mar 21, 2016 06:16 PM
Dragonus18
Sep 9, 2015 01:21 AM
Black_GT_02
Aug 20, 2015 01:26 PM
RedStangGT2000
May 15, 2004 05:55 PM
