Side Scoops
Old Nov 28, 2007 | 12:12 AM
  #21
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: Side Scoops
ThaiCobra PM sent!
Old Nov 28, 2007 | 02:18 AM
  #22
kevworthy's Avatar
kevworthy
I like the side scoops that came on my GT/CS.....They are just like the ones on my 03' GT. I am having a hard time deciding what hood scoop to go with. I am leaning towards the Roush scoop though.
Old Nov 28, 2007 | 07:03 AM
  #23
Nuke's Avatar
Nuke
I don't have a clear, close-uppic of my side scoops also but here are my louvers. Both were bought from hubcapsplus.com and were painted to match perfect. The 2nd pic is both but I'm not sure if you can see the scoops with any detail. The key to them staying put is in the surface preperation:
[IMG]local://upfiles/70965/772B95A01933442999C63C9A63B04170.jpg[/IMG]
Old Nov 28, 2007 | 03:28 PM
  #24
kenthicken's Avatar
kenthicken
I have had no problems with my Cervini scoops (knock on wood). I do think the issue is a preparation issue though. I let mine sit for over 24 hours on the car without driving it. So far... no problems.
Old Nov 28, 2007 | 04:00 PM
  #25
bad1032's Avatar
bad1032
I bought the ford gt/cs for the side and roush for the windows, Did the install and didnt have any problems, guess it pays to do stuff yourself so it dont fall off.
Old Nov 28, 2007 | 04:38 PM
  #26
DarkFireGT's Avatar
DarkFireGT
Hey thanks for being a dick. I was stating my experiences, as well as the information given to me by my bodyguy, with more than 40 years experience. Mine didn't curve exactly with the body either. I was told to put them in the sun for an hour. Did that, and they were very pliable and fit perfectly. I agree it sounds like you haven't had the best customer service. But you're putting the entire blame on the company, and the entire blame does not fall with them. Even if they didn't fit properly, there is plenty of surface area touching the car to be held on. Properly prepped parts being held on with 3M tape do not need much surface area of contact to withstand 100+MPH. Bottom line. I've said my piece and I'm moving on.
ORIGINAL: nothsa
ORIGINAL: DarkFireGT
I've had the Cervinis scoops up and down the track many times without issue. The surfaces must be prepped properly, and 3M quality tape must be used. This was a prep issue, not Cervini's issue.
I'm glad you don't know what you're talking about since the scoops didn't sit flush. It was 3m tape as provided by Cervini's and the paint was prepped correctly. Please don't act like you know what you're talking about because one of your scoops didn't fly off due to poor fitment. For your information I called them about this and they said it was normal which was BS.
-Jeff
Old Nov 28, 2007 | 04:52 PM
  #27
Aziraphale's Avatar
Aziraphale
ORIGINAL: kevworthy
The GT/CS ones require drilling and are more likely to stay on than with just tape if that is what you're worried about. I think they look really nice too. They are probably the ones I will get.
As for the hood scoop, I'd go with the factory one as it has the factory matching style honeycomb.
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
Drastang
Sep 29, 2015 03:31 PM
