Craglist rims will they fit
There ASA JH8 rims. Bolt Pattern 5x114.They are (2)18-8.5 and (2)18-9.5 inch rims satin silver w/ polished machine lip color. The tires are 275/40/18 rear and 245/40/18 front Kuhmo Ecsta. The guys is asking 800 but he should come down some.
RE: Craglist rims will they fit
ORIGINAL: YellowFlame
The offset for 05+ 9"ish wheels is around 36-38mm
The offset for 94-04 is around 24-28.
You may have clearance issues with those unless you go with tiny tires.
You sure about that?
05 wheels are 8" and the offset is 42mm if im not mistaken.
Andrew
Pretty sure.
I did a lot of reading and research (there's a great thread on another forum called Show Us Your Wheels - hundreds of pics, and lotsa pics at American Muscle for example) before ordering new wheels and this is what I have in my notes:
2005
18x9 +34 to +36
18x10 +38
I bought 18x9 +34mm with 255/45R18s. (pic below)
But you are correct, I just went and looked at my old 17x8 factory bullitts and they are 45mm.
[IMG]local://upfiles/83014/BC97B7D0E96A44E0A57ABA68BBC5D5A4.jpg[/IMG]
2005
18x9 +34 to +36
18x10 +38
34-36 is not the correct size, it works, but not correct offset....most are 40+ offset....my GT500 are a 45mm offset (9.5 rim) and if you look at tirerack the offset for the JH8 im 20" it says 45 i think
I actually didnt see andy JH8 18" for our cars, only 20s....they do have a JH9
Either way these will work, they will stick out a little further than stock rims would
Pretty sure.
2005
18x9 +34 to +36
18x10 +38
Pretty sure.
2005
18x9 +34 to +36
18x10 +38
Andrew
