Brake Bleeding Question
Old Nov 30, 2007 | 07:34 AM
Argonaut's Avatar
Argonaut
Default Brake Bleeding Question
I'd like to bleed my brakes at some point and install new fluid and SS lines. I've read up on the subject and understand the basics of having one person slowly pump the brake pedal while the other opens and closes the bleeder valve...doing it for each disk. The sources I found for this did not mention ABS brakes however.
Question 1: Is there anything special we need to do for the S197 with its ABS system?
Question 2: Does anyone make a one way bleeder valve - lets fluid out but doesn't let air in - for this car?
TIA
Old Nov 30, 2007 | 07:43 AM
GidyupGo's Avatar
GidyupGo
Default RE: Brake Bleeding Question
No, and yes. You do know to start with the furthest from the MS don't you?
Old Nov 30, 2007 | 07:50 AM
Argonaut's Avatar
Argonaut
Thanks for the response. Care to elaborate a bit. What do you need to do that is special? Who makes the one way bleeder valves?
Yes, I have read and understand about starting with the disk furthest from the master cylinder (passenger rear)and then working towards the drivers front - thanks for the reminder.
Old Nov 30, 2007 | 08:00 AM
GidyupGo's Avatar
GidyupGo
It's been a while, but I think I saw the bleeders in a JC Whitney book but you could do a search.
Old Nov 30, 2007 | 10:22 AM
howarmat's Avatar
howarmat
s197 Junkie
Do a google search for earls lines and read this
http://forums.bradbarnett.net/showthread.php?t=36934
Old Nov 30, 2007 | 11:26 AM
Argonaut's Avatar
Argonaut
Thanks Howarmat - that post was very informative.
Still looking for any info on special handling for bleeding an ABS brake system. My guess at this point is...there is nothing special that needs to be done. I've seen plenty of posts on how to do the bleeding and none of them have mentioned anything about ABS.
Old Nov 30, 2007 | 01:03 PM
schapman's Avatar
schapman
http://www.speedbleeder.com/
Old Nov 30, 2007 | 10:44 PM
fairlane292's Avatar
fairlane292
ORIGINAL: schapman
cool, anyone using these on S197?
Tivo304
Aug 28, 2023 12:19 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
