Hurst install price
Old Nov 30, 2007 | 12:57 PM
lucki96gt's Avatar
lucki96gt
Default Hurst install price
I have read a couple different diy install walk-throughs online and I really belive me and a helper can do it , but with only 5 more days off for the rest of the year plus the holidays I want to just pay a shop to do it. So what would you guys consider a reasonable labor charge. If its done at a shop with a lift and two people I canlt see it taking more than an hour and a half. How much is good, or better yet is there anyone around Atlanta that knows how to do it and need some shopping $$!
Old Nov 30, 2007 | 01:00 PM
thewarmachine's Avatar
thewarmachine
Default RE: Hurst install price
You should really do it yourself. It is that easy.
Old Nov 30, 2007 | 01:03 PM
stiggy's Avatar
stiggy
its way too easy, maybe an hour and a half tops.
Old Nov 30, 2007 | 01:08 PM
howarmat's Avatar
howarmat
s197 Junkie
whatever a shop charges for 1-1.5 hours of work
Old Nov 30, 2007 | 01:11 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I really suggest you and a friend, but sometimes its just not feasible, so if you must go to a shop, I would not pay more than 50, maybe 75 tops.
Old Nov 30, 2007 | 01:12 PM
acascianelli's Avatar
acascianelli
Do it yourself, as said before, it will take an hour tops. You'll probably spend more time figuring out how to get the new shifter through the hole in the trans tunnel than actually loosening and tightening bolts. This was my first mod and it took me an hour after work.
Old Nov 30, 2007 | 01:19 PM
lucki96gt's Avatar
lucki96gt
I know it has to be easy from everything I read. I guess I will get up Monday morning to pick it up from summit, and come home to do it, can I really complete it 1.5hrs by myself?
Old Nov 30, 2007 | 01:23 PM
acascianelli
ORIGINAL: lucki96gt
Yes, as long as you can get the car off the ground enough to work around the transmission you'll be fine. I used a set of ramps. Like I said before, the hardest part is getting the Hurst shifter back through the hole in the tunnel. It will seem like it won't fit, trust me it will. You won't be able to use a socket & wrench for the forward mounting bolt, make sure you have a slim wrench to fit in there.
Old Nov 30, 2007 | 01:31 PM
mightymouse's Avatar
mightymouse
I did mine my self with no help took like 2 hours most of that time was spent trying to get the shifter through the trans tunel.
Old Nov 30, 2007 | 01:39 PM
PullMeOverRed05's Avatar
PullMeOverRed05
ORIGINAL: thewarmachine
+1 dude.. all of 45 minutes. You should give it a shot
