Need electrical help...
Old Nov 30, 2007 | 06:22 PM
Ortoch's Avatar
Ortoch
Default Need electrical help...
I just ordered a Beltronics STI Professional Radar Detector and it comes with a direct power cord. The instructions for this are as follows....
Direct-Wire
Power Cord
The Direct-Wire Power Cord comes with connectors to allow easy hook-up to your car's electrical system.
The black ground wire is fitted with a lug to allow it to be installed under any grounded screw under your vehicles's dashboard.
The red striped wire for +12 volts is fitted with an insulated 1/4" male spade lug. We also have supplied a special 3M connetor that allows you to tap into an existing wire in your vehicle. This connector can be used only with wire guages 14 through 18.
To install the connector, position in around the wire you wish to tap into, and squeeze it with pliers. The Direct-Wire can then be plugged into this connector. Make sure the clear insulator sleeve on the Direct-Wire completely covers the connection.
Basically I am trying to figure out what wire is best for this crimp and how best to get at it. Thanks a mil for the help!
-James
Old Nov 30, 2007 | 08:09 PM
hammeron's Avatar
hammeron
Default RE: Need electrical help...
if it were me......i would use
a mini add-a-circuit (pic available
if you need it) and use (unused) fuse position
13 (passenger foot area fuse box)
for the ground, i would use the ground
screw located behind the glove box (pic
available if needed)
this way you can isolate your device(s) with
fuse protection.
are there other ways to accomplish your
objective? of course.....
Old Dec 1, 2007 | 05:32 AM
Ortoch's Avatar
Ortoch
I am extremelyyyyyyyyyyyyyyyyyy electronicly illiterate when it comes to cars so I understood about 1/4th of what you said. I can get a fuse that will have a power cord comming out of it for the fuse box? is that correct? well assuming thats correct my radar detector would get power from that how? and also the radar detector has this hardwire settup with buttons on it how would I adapt this to the fuse attachment?
well hope you can offer assistance here thanks
Old Dec 1, 2007 | 08:58 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Ortoch
I am extremelyyyyyyyyyyyyyyyyyy electronicly illiteratewhen it comes to cars so I understood about 1/4th of what you said. I can get a fuse that will have a power cord comming out of it for the fuse box? is that correct? well assuming thats correct my radar detector would get power from that how? and also the radar detector has this hardwire settup with buttons on it how would I adapt this to the fuse attachment?
Nix the install by yourself and get someone to put it in for you
that knows what they are doing. Dont use that 3M wire tap
device that was included with the radar detector. Go to
AutoZone and ask them for the fuse tap device and wiring
advice.
Off subject, can someone help me bake a cake?
I am extremelyyyyyyyyyyyyyyyyyykitchen illiterate.
Old Dec 1, 2007 | 09:56 AM
Rainson's Avatar
Rainson
Im wondering the same thing,I want to hook it up to the fuse of the CD player,I cant find it.haha...Need pics
Old Dec 1, 2007 | 10:16 AM
mlcrycc's Avatar
mlcrycc
Since Hammy's offline, I will throw a couple of pics up, that are the pieces he was describing.....
First pic is the Add A Circuit referred to. Be aware that when you go to the auto parts store to get it, you need the smaller size Add A Circuit for our cars, not the standard fuse size. They will have both.
Second pic is showing the Add A Circuit connected to the fuse box inside the passenger side kick panel fuse box. It is connected to a different fuse than Hammeron referred to. Use the one he noted, as it is switched power, not constant hot.
Third pic shows a ground screw that is right in front of the fuse panel. Very convenient....
Hope it helps....
[IMG]local://upfiles/13557/BD7CD706A3954061812AE6D0CB101A9F.jpg[/IMG]
[IMG]local://upfiles/13557/2BC0BE716D824BB3A0F65AE67D96D5C6.jpg[/IMG]
[IMG]local://upfiles/13557/5A309656188A4F9CADC456775C4C0762.jpg[/IMG]
Old Dec 1, 2007 | 10:33 AM
hammeron's Avatar
hammeron
thanks mlcrycc, excellent pics. i
will probably use them in the future,
when describing this procedure
Old Dec 1, 2007 | 10:37 AM
mlcrycc's Avatar
mlcrycc
ORIGINAL: hammeron
[sm=smiley20.gif][sm=smiley20.gif]
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
