D-Spec Install Question
Old Dec 4, 2007 | 12:41 PM
Simon1's Avatar
Simon1
Default RE: D-Spec Install Question
I over tightened the rear shock and and when I went to to remove it, it cross threaded. All my fault. It's gonna be a bitch getting it off to replace it.
Old Dec 4, 2007 | 12:55 PM
Sherwood06GT's Avatar
Sherwood06GT
ORIGINAL: hammeron
sherwood, how do you like the
new setup
So far, I like them a lot. Just waiting for a dry day so I can take a corner at more that 20 mph. [&:]
Raining cats and dogs the last few days, as you know!
Old Dec 4, 2007 | 02:14 PM
Black05StangGT's Avatar
Black05StangGT
I love mine...they handle like a dream...I still need to get the alignment checked, but it must not be way off because it doesn't pull hard to the left or the right...I wanted to let everything settle before the alignment...and make sure I didn't need to make any other kinds of adjustments...
Old Dec 4, 2007 | 02:42 PM
torch red's Avatar
torch red
Curious to know the setting you guys use..
I am in the middle..
Old Dec 4, 2007 | 02:46 PM
Black05StangGT
Mine are pretty much in the middle all the way around...
Old Dec 4, 2007 | 02:50 PM
alloutt's Avatar
alloutt
Should have got camber plates too, I had mine professionally installed.
hammeron's Avatar
hammeron
yeah..... i saw on the news
about flooding out in those parts....
glad you like the setup, so far
ORIGINAL: Sherwood06GT
ORIGINAL: hammeron
new setup
Old Dec 4, 2007 | 03:25 PM
Black05StangGT
I have the steeda caster camber plates/upper strut mount...
Old Dec 4, 2007 | 06:57 PM
Argonaut's Avatar
Argonaut
In addition to the front strut top nut there are two other locations that are basically the same - a nut over a shaft where you need to apply opposite pressure to the nut and the shaft: The rear shocks top nut (torque to 30) and the front sway bar end link (torque to 85). Its the same problem, you tighten the nut and the shaft turns. This precludes using a torque wrench in a normal way...i.e. with a socket. So how the heck is it suppose to be done, there must be some special tool.
Anyway - what I'm taking away from this is most people don't worry about the proper torque and just tighten them down as best they can.
Old Dec 4, 2007 | 07:08 PM
modaddict's Avatar
modaddict
I just got them as tight as I could before it started to turn the shaft. I've never had an issue with it so I assume it's good. For the question of where you set them...
In the front (I sold the rear shocks as I didn't like them and had better 60's with the stock shocks) I keep them at 4 turns out for the street and 6 1/2 turns out at the track.
I cut 1.40 / 1.41 60's...
