Breaking in Gears
Breaking in Gears
My car was finished today, had 4.10s installed [sm=badbadbad.gif]
What is the break in period for gears, I think I heard somewhere. Just drive around the block, let cool, then do it again, then they are good to go. Is that how it goes?
RE: Breaking in Gears
I have found there to be wildly different opinions on this. I had FRPPs installed by CJ Pony Parts (who do lots of them). They told me no breakin required and no change of fluid required in near future. I have seen others post that you should break in easy for 500 miles and also change fluids at that point. Go figure.
Applying a little logic - cars come from factory with new gears. There is no stated break in for them nor requirement to change fluids at 500-1000 miles. So...why would it be required for a replacement? I don't know, but I trust my installers.
Opinions will vary greatly on this .. I do a few heating and cooling cycles and change the fluid at 500 miles. If you've ever changed the fluid with new gears on a differential cover thats got magnets, you'll want to do it again.
ORIGINAL: Argonaut
How much did you pay total if I may ask?
Because I live an hour away from there and I've been looking for a good installer.
ORIGINAL: sleeper2
My mechanic said to go through 2 or 3 heat cycles (if that) and then not to worry about it.
Sleeper2
Sleeper2
[sm=gears.gif]
I know when I had the 3.73s done under warranty on my 04, I never went back for the fluid change. Was never told to either. i'm just gonna do the heat cycles and leave it at that.
ORIGINAL: rshamekh
How much did they charge you for the install? And did you buy the parts form them?
