Frickin piece of crap shaker 500 killed
#21
RE: Frickin piece of $h1t shaker 500 killed
ORIGINAL: lrgnation
its not the shaker thats the piece of crap for staying on, Your bcm has a problem with the power to the stereo. Its your cars "computer" causing the problems in this case. So maybe ask the tards at ford to help you out.
And for everyone who keeps telling him to short out the circuitry by pouring water on it, pulling it apart or just plain vandalizing it... WRONG! I deal with warranty administrators and adjusters everyday. Stereos are a core item and as soon as they are disassembled for inspection and found to be screwed with, guess who gets the bill? The one who screwed with it!
Ford has a jacked up warranty system, I admit. I went in to have my instrument pack bezel and a couple of vent rings replaced due to the chrome blistering. They told me they had to do "digital imaging" of the affected parts and send the "images" to Ford for evaluation. Basically they took picturesto verify I didnt modify my dash in some way that would cause the blistering. Complete BS, but I put up with it and was givennew components. Because of Fords financial situations, they are trying everything they can to deny warranty claims. In the long run this will only hurt their Customer Service Index because they are forcefully dropping their Warranty Index by pulling this BS. Just be persistant, dont throw a fit, and if one person wont help you, go higher than him. You are the client, you bought the car from them, you make their paychecks.
#22
My 2007 Shaker 500 was DOA. It wouldn't play CDs and gave an error at start up. I was given the option of delaying pickupor taking the car and having it fixed under warranty. Gotit fixed a few weeks later.
JP
JP
#24
ORIGINAL: lrgnation
#26
Question: Are the amps for the 500 fused separately from the radio? Try pulling those when you read the high draw current. The headunit has a wire that goes to the amps to turn them on/off; it's a 5V wire. My guess is that wire isn't always switching off. If you pull the radio fuse, it likely switches it off.
My issue with my Shaker 500 was crappy performance; at certain bass frequencies it sounded like there was 10-20 dB sound reduction. I didn't hear some songs that started with bass note intros until the singer started in. Cheap JVC headunit fixed 90% of it, before playing with balance.
Tom
Tom
#29
ORIGINAL: thxultra
Dump the pos and go after market. I went with a pioneer d3 and love it. Thier are many nice after market setups that wll make you much happier then the skipper.
#30
ORIGINAL: Va. Stang
If this does not work out at the dealer I am looking for a head unit to replace to shaker 500. One I can hook a back-up camara up to.
ORIGINAL: thxultra
