Used Gears
Old Dec 10, 2007 | 07:41 PM
Gene K's Avatar
Gene K
Default Used Gears
I have a set of Ford OEM 4.10 Gears for a 8.8 that are out of a wrecked low-mileage Explorer.
They look like new. Has anyone ever tried installing used gears?
I know the contact pattern will change some. Is this an issue?
I dont see why it wouldnt work. I have changed Diffs before and reused the stock
gears and this would move the contact pattern also.
Old Dec 10, 2007 | 07:52 PM
marcuskeeler's Avatar
marcuskeeler
Default RE: Used Gears
I wouldn't install used gears if they were given to me free
Old Dec 10, 2007 | 07:53 PM
jerjan's Avatar
jerjan
They will work, They will most definately make noise. Not a recommended process.
Old Dec 10, 2007 | 07:56 PM
Legion5's Avatar
Legion5
gears are inexpensive the instal process is the expensive part, why take the risk?
Old Dec 10, 2007 | 08:01 PM
Gene K's Avatar
Gene K
ORIGINAL: jerjan
Thats what I was afraid of.
Install is free (Im good buds with the Ford Tech that does the gear installs at the local dealer.)
PS Why does changing the diff but not gears (Open to locker) not cause noise? I know the contact pattern changes.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
