Electronic problem???
Old Dec 13, 2007 | 02:02 AM
Ortoch's Avatar
Ortoch
Default Electronic problem???
Ok I installed a hard wire kit for my radar detector through my passenger side fuse box... well the wire broke today and after I got it stripped and reconnected I turn on the car and my "Check Engine Light" is on... could that be something with the fuse box or is it just a really bad coincidence?
For some backround on the install I used a "Add a fuse" and was/am running 2 10amp fuses out of one 10 amp fuse slot (supposedly these are used alot and I shouldnt have this problem).
Well hope someone knows if this is teh fuse or not and how I can fix it myself if possible. I have a SCT X-CAL2 that I can reflash the comp with and then put my tune back in if that will fix it.
thanks for the help,
James
Old Dec 13, 2007 | 02:47 PM
Ortoch's Avatar
Ortoch
Default RE: Electronic problem???
I just checked and I had a 15amp and a 10amp fuse in one of the slots... could that have caused it?
Old Dec 13, 2007 | 03:00 PM
howarmat's Avatar
howarmat
s197 Junkie
did you pull the CEL code?
Old Dec 13, 2007 | 03:25 PM
DocVenture's Avatar
DocVenture
Unplug your battery cable for 15 minutes to clear it. I doubt it'll come back on.
Old Dec 13, 2007 | 03:40 PM
Ortoch's Avatar
Ortoch
how do i do this?
ORIGINAL: howarmat
Old Dec 13, 2007 | 03:43 PM
howarmat's Avatar
howarmat
s197 Junkie
use your tuner, it has a "read code" option
Old Dec 13, 2007 | 04:07 PM
Ortoch's Avatar
Ortoch
OK I did the read DTC option and it found 3 codes.... 0153 0462 2067 how do I look up what those mean?
Old Dec 13, 2007 | 04:19 PM
imyy4u's Avatar
imyy4u
ORIGINAL: Ortoch
yes, it can cause a MIL for the electrical system.
Old Dec 13, 2007 | 04:20 PM
Ortoch's Avatar
Ortoch
oh btw my cruise control WONT work anymore... weird?
Old Dec 13, 2007 | 04:37 PM
howarmat's Avatar
howarmat
s197 Junkie
sounds like you blew other fuses or a relay maybe
