Header Install
Old Dec 13, 2007 | 03:33 PM
sailing220's Avatar
sailing220
Default Header Install
I'm doing Longtubes and a Prochamber soon. What are some other worthy mods to do when I'm down there?
Old Dec 13, 2007 | 05:36 PM
black S197's Avatar
black S197
Default RE: Header Install
ORIGINAL: sailing220
Motor mounts.
Old Dec 14, 2007 | 08:20 AM
SuperSonic05's Avatar
SuperSonic05
why motor mounts
Old Dec 14, 2007 | 09:02 AM
281GT's Avatar
281GT
The stock engine mounts allow a lot of engine movement. Too much in fact. You'll get more power to the ground by limiting engine movement with after market mounts. This mod will also improve shifter performance in manual equipped cars. This happens because the stock mounts allow so much engine / trans movement that at WOT the body mounted shifter can bind.
Also with some brands of long tube headers there can be an interference problem between one of the primary header pipes and the steering shaft.
Aftermarket engine mounts are an inexpensive mod that will be easy to do while you are installing the headers.
The only downside is slightly increased NVH but they are well worth it.
Old Dec 14, 2007 | 10:14 AM
05Saleen#243's Avatar
05Saleen#243
Aluminum DS and short-shifter if you've got the money.
Old Dec 14, 2007 | 11:48 AM
Simon1's Avatar
Simon1
Motor mounts for sure. EASY to install and worth the money. They keep your motor from moving from side to side during load which helps alot of things. It won't make your car vibrate crazy or anything like that. You will notice it at start up and shut down the most.
Old Dec 14, 2007 | 11:53 AM
MexGT's Avatar
MexGT
First get a couple of beers because you´ll be down there a good while !!!
and yes MM´s are a good option also!
Old Dec 14, 2007 | 11:57 AM
cbrstng08's Avatar
cbrstng08
What are some good aftermarket motor mounts adn has anybody done an install how to on them for the S197's?
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
