D-Specs
If you order and install just the D-Specs you do not need to purchase anything additionally. You will have to scavenge several parts off your stock struts however: bumpstop, dustboot.
Problems after lowering? Not sure what you mean. The D-specs are dampers, they don't cause any problems. Are you talking about lowering springs and the *possible* problems they can cause? - camber out of spec, toe out of spec, rear axle off center, possible scraping if you go to low.
ORIGINAL: Argonaut
Your problems (if lowered) will be caused by the lowering of your car itself. A adj panhard bar will help. Save this link and read post #4
https://mustangforums.com/m_1696246/...tm.htm#1696246
STANGSUSPENSION
May 21, 2008 01:17 PM
