Wind noise at 90+
Wind noise at 90+
So I'm on the highway going about 90 and I hear this wind noise coming from the rear somewhere. I stop and check to see if the passenger door is closed all way which it was, the windows were up and tight, I think it's coming from a rear side window or more likely the back glass, anyone else hear the same noise?
RE: Wind noise at 90+
Hmmm, well first off... let's not kill someone driving 90 on the freeway.
Anyways, on a pretty windy day, I can hear that same kinda noise in my 00 stang when on the highway. Unless it's really bad, it's probably something totally normal.
I have been up there a couple of times in my 05 GT. I don't recall the noise your are speaking of. I can here that engine pushing along though.
Have you been through a car wash yet ?? I use a touchless, nothing but high pressure water wash. My pass, side window has a small leak, water drips down the inside of the car.
This may indicate some fit issues with the side glass. Not sure though.
ORIGINAL: Shifty
I've maxed the speedo and I don't hear any unusual noises.
ORIGINAL: dajohu
Cool! Did it stop when you got to max speedometer mark of 149mph (240kph) or did it actually go past the last mark? What was the engine RPM?
ORIGINAL: Shifty
ORIGINAL: Higgie
ORIGINAL: Shifty
Stops at the last mark which is 145 I believe. I can't remember what the revs were.
ORIGINAL: dajohu
ORIGINAL: Shifty
