AVIC D3 Installation Upcomming...
Ok I did alot of research just now and belive I know most of the questions about the detailed aspects of the install but I am unsure on how to START this project... i.e. taking interior panels off and what not. Heres my questions if anyone has a detailed write up of a radio install in a S197 coupe or a D3 install (even better) lemme know.
Before the questions heres a list of the things I have comming... let me know if I need anything else please
- CD-R55 - Pioneer Wireless Remote (#76946): 1
- CD-BTB200 - Pioneer Bluetooth Wireless Adapter (#77081): 1
- AVIC-D3 - Pioneer In-Dash Double-Din DVD/Navigation Receiver System (#76441): 1
- CD-I200 - Pioneer iBus Interface Cable for iPod (#76507): 1
1. How do I get the center console off?
2. What should I be looking at as the main problem points during an install like this?
3. I am have a wire stripper/cutter and a whole slew of 22-18 guage crimp-on butt connectors do I need any other specific extra parts/tools?
4. Anything else I should know???
Well I apriciate the time and hope that someone can help me out. I will be installing next week so no rush but the more info I can get before I start the easier this will be probably.
Thanks a mil,
James
Thanks a mil,
James
RE: AVIC D3 Installation Upcomming...
first off, either order or go pickup a haynes manual from autozone/pepboys/etc so the proper way to disassemble your dash is with you. following that installing the radio is very simple provided you have the right tools.
aside from the items you mentioned, you will need the following to install:
1) Wiring harness for either the standard or shaker500/1000, best buy or circuit city sells these
2) a dash kit for a S197
3) Crimp tool, wire stripper/cutter and crimps
4) patience
you'll also need, i believe, a philips screwdriver and a 7mm nut driver
that should be everything you need, your harness should come with a wiring diagram and the haynes takes care of removing the radio steps, took me about 1hr to put this in, we were working kinda slow and it was my first try with a Nav system.
everything else can be found in my AVIC-D3 Answers sticky, i'll post pics of it finished in a bit
4) patience
ORIGINAL: SatinSilverStang
4) patience
4) patience
I'm having mine installed on the 5th. A buddy of mine installs sound systems for a living at Best Buy, and he's doing it for $30, pizza, and beer. The beer comes after the install is done. LOL.
ORIGINAL: howarmat
its very easy, follow some of the tacobill write up and you should be fine
if you have the shaker 500 you also need a 5v voltage regulator I believe, not sure if that is the correct voltage but you do need something to regulate the volts otherwise there will be a loud popping noise when you turn the car on.
ORIGINAL: nonstopred
ORIGINAL: Ortoch
I need to know what kind of regulator or resistor to use and a write up on where to install... I have a soldering iron so thats no problem just lemme know which one if you know
Mike
http://www.dennisjudd.com/archives/000947.html
