BBK CAI
ORIGINAL: Leoleo
I got and no tune, no problems. So NO it does not need a tune.
ORIGINAL: howarmat
your havent had a code thrown yet, doesnt mean you wont get one......if you are getting a code, then it aint doing **** for you really either...
Anyone that says you NEED a tune is just trying to sell you something. And you may what that, which is okay.
ORIGINAL: Leoleo
Wrong, colder air, hence more/denser air, means more power. Yes it would produce more with a tune, but it does not need a tune. The question is does it NEED a tune. Not do you WHAT a tune. And with the BBK CAI you do not NEED a tune. Maybe only 10 to 15 more hp without a tune, but there is a difference.
ORIGINAL: howarmat
If you think tuning is just a gimmick then you don't know what the hell you're talking about.
ORIGINAL: Leoleo
ORIGINAL: howarmat
The above post is correct, to get ANY gains that are worth talking about, you have to lean out the a/f ratio for a STOCK tune
I was running 87 octane. Yesterday changed bact to stock and went Advance Autoparts to do a scan. I was running lean in banks 1 & 2. I had them clear the code.Its not that I didn't want a tuner and intake just had enough money for an intake. I had thought about an Airaid at one time but changed my mind. Now have to save some money and buy the tuner. Above all lesson learned.
I have a BBK 62mm TB and CAIK. I found a great deal on a Diablo Predator (in the classifieds here) and loaded the 93 octane tune. Big difference. Once loaded NEVER run a load of 87 or you'll be sorrrrry.
ORIGINAL: acascianelli
The ECM will compensate for colder air, thats what a IAT sensor is for. What it will not compensate for is increased volume of air passing the MAF sensor. That's why a tune is needed. If you run an intake such as a; BBK, C&L without no-tune insert, Steeda(all pretty similar), you will be running lean.
I just read through some documentation on BBK's site and they do say that a tune is not required; Brenspeed also says that a tune is not required. I was wrong, I apologized. Looking at pictures of a JLT/C&L compared to the BBK, you can see that the inlet of the intake is much smaller than the JLT or C&L, meaning that it's probably the same diameter as the stock intake thus not requiring a tune.
