anyway to retain stock shift knob with hurst shifter?
anyway to retain stock shift **** with hurst shifter?
i actually really like the look of the stock shifter,but really want the short shift,is there a way to the stock shifter with some modifications?
RE: anyway to retain stock shift **** with hurst shifter?
Not sure if it's possible or not, but I would think that the stock shifter **** would look a little odd on the Hurst chrome stick. If I were going to keep the stock ****, I'd look at an MGW or Steeda.
ORIGINAL: 300GT
ORIGINAL: 300GT
Besides, the coolest part of the Hurst, IMO, is the white ball!
ORIGINAL: 300GT
I have the MGW with the stock ****. You can't even tell it's in there until you actually go to shift.. Looks 100% stock.
yeah,i wanted the mgw,but the hurst was cheaper,i really like the stock shifter and boot.id like to figure out a way to reduce the shifter height and re-use the stock **** to make it look more like stock.guess ill have to take a look when it shows up,otherwise i may just send it back.
Since the threads are differents, you would have to use some kind of helicoys (check spelling on that).
Either that, or can the Hurst handle for a custom one. Not practical.
I did 5.0 handle for a customer (bolts right up to the Hurst small arm), but he used a SVT **** witch is similar to the stockS197.
It was a weird set-up
The stock shift hand from what I understand is interchangeable with the Hurst. So rather than installing the hurst bar, reinstall the stock one on it. But the Hurst bar is taller than the stock so it would look way funny with the stock shift **** on it.
ORIGINAL: one eyed *****
here's another option if you want to keep the stock shifter and just shorten up the throw. A couple of forum members have done this and seem to be satisfied with the results.
