Roush Louver Problems
Old Dec 24, 2007 | 02:44 PM
BlueDemon07's Avatar
BlueDemon07
Default Roush Louver Problems
I just installed my Roush quarter window louvers and they look great. The only problem is that the screws just don't seem to be very secure. I have had one come loose already. If any of you have installed them yourself, did you use loctite on the screws to keep them from backing out or anything else of that nature? Any help would be greatly appreciated.
Old Dec 24, 2007 | 04:42 PM
bad1032's Avatar
bad1032
Default RE: Roush Louver Problems
Yes i used blue. get all 3 started then tighten them down equal
Old Dec 24, 2007 | 05:24 PM
BlueDemon07
Thanks for the info. I was going to use red because even though it's permanent, I figured I could get a 1/8" screw to break loose no matter what is on it. Do you see any problem with using red?
Old Dec 25, 2007 | 12:12 AM
Cobrakev's Avatar
Cobrakev
First make sure you are not allowing the screw to bottom out on the car itself. Not only will this scratch the paint, but it will not allow the screw to tighten down. I had to bend one of my attach brackets to keep a screw from touching the paint.
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
TimeLord101
Sep 4, 2015 09:27 AM
5.0 kevo
Sep 3, 2015 06:24 PM
