Shaker System and my options
yea i would but im only 19 and not enough experiencedd to cut a whole in my hood lol....if a body shop does it, even better, i was just curious about which other hoods i could use if i wanted to
CDC sells the Foose hood, which Pascal has... And Cervini's sells thier B-series hoods which will also fit. But if you don't want to cut the hole, let the Body shop cut the hole and you do the rest so you can atleast save some money. But I wouldn't pay them more than 1 hour of labor to cut the hole, it's all it should take. Really the longest part of cutting the hole is lining up the template. But after that, the hole cutting only takes, 5 minutes.
ORIGINAL: Boozshey
About your stripes, yes, vinyl will start to mess up, when, who knows, mine lasted about a year and a half, but are a metalic silver, which has been the worst... But painting them on will ALWAYS be better.
not to highjack, but a word about the vinyl stripes - not all are made the same (obviously). i had my stripes installed by a custom signage shop (they typically make vinyl signs for vans and trucks, etc.). the stripes they put on come with a five year warranty. so big bucks for painting is not the only option, albeit it is the best one if you have the dough
ORIGINAL: ink003
For those who don't know...
The Foose hood doesn't come with the trim ring because of the bulge in the middle, from the 69/70 Stangs.
Since CDC provides only the one for the OEM only, you're f###d. And that's total BS.
When I ordered the whole deal, I expected a matching trim ring[:@]. They told me "you don't need any"... [&:]
I'm like what? Am I suppose to use your foreskin insteador something??
Anyway, I had to modify the regular one
Used a dremmel and a heat gun. Also 320 grit sand paper.
[IMG]local://upfiles/78700/786654832E744CB397226574EB59A265.jpg[/IMG]
[IMG]local://upfiles/78700/7362243C44BC4FFC9CB22CEDE6D28AED.jpg[/IMG]
.Used a dremmel and a heat gun. Also 320 grit sand paper.
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
