Question about a Fuel problem!!
Yeah i might look into that. I think the pumps would be alright if it wasnt such a cluttered tight fit. With all the extra hoses and wires there is more to go wrong thats for sure.
I've had many issues when I installed my Dual Fuel Pumps. Everything is fixed now but if your not careful a couple things can go wrong.I know one sender can cause the gauge to read empty. I would make sure that the wires are all secured and the hoses are clamped REALLY hard I had 2 tubes blow off since the clamps wern't tight. The first picture would cause my gauge to read empty at a little under half a tank even though it never ran out of gas.
ORIGINAL: meekstro
thats exactly what mine is doing. Right when i got under a half a tank it started that. How did you correct it exactly? Thanks alot
oh ok...thanks a ton..ill have to pull it out this week and see exactly what has messed up. That sounds very much like my problem. I appreciate all the help guys.
ORIGINAL: meekstro
Well I pulled the fuel pumps back out and looked over everything again. None of the hoses were loose and all my wires were intact. I checked the fuel sensor and it wasnt cracked but it looked like it might not be making good contact. I fixed that and put it back in. I havent had any problems yet but have not driven the car enough lately to get my fuel low again. Hopefully its fixed. Thanks for everyones help.
ShaneB26154
35
Mar 4, 2021 04:05 AM
