Tire Pressure Monitor Light Blinks...
Old Jan 2, 2008 | 08:30 PM
drfnw's Avatar
drfnw
Default Tire Pressure Monitor Light Blinks...
I have a new to me 07 v6 convertible stick with ABS, Traction Control, and the standard Tire Pressure Monitor System with 17" GT wheels. More often than not at startup the TPMS warning light will blink on and off for about 20 seconds, then goes out. I have checked Tire Pressure on fire tires and spare, all are good and the four road wheels are within a half pound of each other.
Is this normal or not? Thanks.
Old Jan 2, 2008 | 09:27 PM
Stoenr's Avatar
Stoenr
Default RE: Tire Pressure Monitor Light Blinks...
There is most likely a bad sensor. I would have it taken in. It may say this in the owners manual that its a problem in the system.
Old Jan 2, 2008 | 10:39 PM
One Bad Stang's Avatar
One Bad Stang
if all the pressures are good then it would have to be a sensor problem. take it to the dealer and have them fix it.
Old Jan 2, 2008 | 11:13 PM
mustangsally07's Avatar
mustangsally07
if it only blinks for 20 secs. right after u start it up it could just be a bulb check for your instrument cluster lights
Old Jan 8, 2008 | 02:51 PM
drfnw's Avatar
drfnw
For the record, I took it back to dealer. The 17" GT wheels they swapped onto the car had no monitors inside. oops. They ordered the parts, and will install at their expense. So its all good. I post this just so people with a short blinking light would know that--at least in this cae--it was a sign of no sensors being present.
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
zachary1988
Sep 4, 2015 03:04 PM
amandahchase
Sep 3, 2015 10:09 AM
