E-Brake Seized Up !!
Old Jan 3, 2008 | 09:15 AM
NyFordTech's Avatar
NyFordTech
Default RE: E-Brake Seized Up !!
warrenty even if the tsb dosnt apply
bumper to bumper 3 yrs 36000
Old Jan 3, 2008 | 11:27 AM
SuperSonic05's Avatar
SuperSonic05
Okay, my e-brake did seize up on New Years day. I did not have it all the way engaged, so I did not notices until I took my foot off the gas and it felt like I was braking. At a stop, I pull on my e-brake and felt no resistance. After letting the car warm up all the way, I pull the e-brake all the way and back down, then it released. Since the E-brake is fine now, how do I get a dealership to fix it? Is there anyway on line to check when my warranty is up?
Old Jan 3, 2008 | 11:54 AM
howarmat's Avatar
howarmat
s197 Junkie
There is a TSB on the freezing parking brake.....take it to a dealer
Old Jan 3, 2008 | 11:57 AM
NickSezz's Avatar
NickSezz
It must be winter again......
MrSandman's Avatar
MrSandman
You heater only heats the inside of your car.
As a general rule for almost any car.. never put your e-brake on in temps below 30 F. Especially if it has been damp before the temp dropped.
ORIGINAL: Larmo
Its a good thought, but this morning I started the car a good 20 minutes before I tried to leave. I had the heat on full blast while the car was warming up. Then again I am a vert so the ragtop may disappate heat more than a hardtop.
I'm heading home for lunch to play around with it. I will let you guys know what I find. Thank you to everyone for their help. This site is amazing.
Old Jan 3, 2008 | 11:59 AM
howarmat's Avatar
howarmat
s197 Junkie
I am going to start moving all the ebrake cable freezing to useless.....it is in 1 of the stickies at the top and there is a tsb link at the top of the page....
Old Jan 3, 2008 | 12:04 PM
StickShifty's Avatar
StickShifty
pretty common in all cars. had it happen before to me in a truck. its a pain!!
Old Jan 3, 2008 | 02:25 PM
Larmo's Avatar
Larmo
Checked it again about an hour ago. Its gotten much warmer but the e-brake is still not functioning. The e-brake handle still moves freely. I guess I'm going to have to crawl up under the car tonight and see if I can see the cable catching on anything. Otherwise, not sure how I'm going to get it to the dealership for warranty work without getting her towed.
Old Jan 3, 2008 | 02:51 PM
howarmat's Avatar
howarmat
s197 Junkie
Like stated in the stickied thread....if you go and work with the cable around the rear wheels it will come loose, when the level is disengaged there should be play in the cable to tug on and such.....the boot gets frozen then cracks, thus allowing more water to get in there and freeze. you can also drive around a little bit (around the block), you will drag the brakes but it will help it break free.
Old Jan 3, 2008 | 02:55 PM
Mustang_guy17's Avatar
Mustang_guy17
Glad I never use my E-brake.
