Sponsored by:
Sponsored by:
Are these safe to remove?
Old 01-03-2008, 02:37 PM
CroDalmatinac
CroDalmatinac's Avatar
Default Are these safe to remove?
My rear seat delete kit will not sit flush because these screws are in the way. Is it safe to remove them so it can sit flush?
[IMG]local://upfiles/37372/BFD7DFC1D6EE4F399A22192DEFD6887A.jpg[/IMG]
[IMG]local://upfiles/37372/C69E23125E1B4F598087BC0554EFD2FA.jpg[/IMG]
[IMG]local://upfiles/37372/3202F967B9304F328DAC62866C5415E3.jpg[/IMG]
CroDalmatinac is offline
Old 01-03-2008, 02:44 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: Are these safe to remove?
Rather than remove them altogether, you should get some flush mount button allen bolts.
They make some that will be flatter and the allen will be recessed almost completely into the threaded shaft. You just have to search for them.
Derf00 is offline
Old 01-03-2008, 02:46 PM
WPsharpshooter
WPsharpshooter's Avatar
If you remove them, your rearend will fall out..... Rofl
WPsharpshooter is offline
Old 01-03-2008, 02:52 PM
howarmat
s197 Junkie
howarmat's Avatar
every other mustang has these bolts in there, and do not complain about the seats sitting flush?
howarmat is offline
Old 01-03-2008, 02:57 PM
smythge
smythge's Avatar
ORIGINAL: howarmat
I was thinking the same thing, but he has a rear seat DELETE kit.
smythge is offline
Old 01-03-2008, 03:10 PM
howarmat
s197 Junkie
howarmat's Avatar
ahh i missed the delete part, oops!
howarmat is offline
Old 01-03-2008, 03:19 PM
sevenleaf
sevenleaf's Avatar
Where do you get these? I tried home depot, NAPA, Autozone...
ORIGINAL: Derf00
sevenleaf is offline
Old 01-03-2008, 03:29 PM
157dB
Cut & Paste Expert
157dB's Avatar
If you replace them with button head fastners,
be sure and get thesame grade offastners as
the OEM originals.
These bolts hold your UCA bracket on the vehicle.
A snapped bolt here would be devistating at high
speeds.
157dB is offline
Old 01-03-2008, 03:40 PM
RED121572
RED121572's Avatar
[quote]ORIGINAL: sevenleaf
[quote]ORIGINAL: Derf00
Contact Rick Wildman @ Columbus Fasteners. 614.486.6670
The guy can get you any bolt you want.
RED121572 is offline
Old 01-03-2008, 04:11 PM
pascal
S197 Section Modder-ator
pascal's Avatar
You could always drill your delete panel and bolt those screws back. Or drill bigger than the bolts head and let them stick out.
Just a thought...
pascal is offline
Quick Reply: Are these safe to remove?
