back fireing
Old Jan 4, 2008 | 12:21 AM
brendend's Avatar
brendend
Default back fireing
ok... i think a coil pack is on its way out because about 75% of the car seems to... i dont know how to word it other then. limp. so the other day i unplugged the coil packs 1 at a time and found that its the2nd cylindercoil pack. so i didnt think it could cause any big problems and im waiting on taking it to ford instead of right in like i originally planed because i just got a few side jobs... anyway.... about 5-6 days ago it started to back fire randomly.. i mean its a full blown back fire... loud as hell and horribly embarassing. well..i didnt know a bad coil pack could do that... you can feel when the coil pack is working since the car has a sudden boost of power, and it dosentt back fire then. it seems to be backfiring when the coil pack isnt fireing... any ideas on what to do other then get it onto ford asap? or could something have gone bad because of the coil pack.
Old Jan 4, 2008 | 08:56 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Default RE: back fireing
You know, it just hit me[&:]...
I believe they replaced the radiator support on that car of yours... Witch involves welding.
When you weld on cars, you disconnect the battery for sure and some electronics. Electronic components don't do good with hight amperage[8D]. Ouch! Not cool.
Do you know for sure if that battery was ever disconnected?
I have seen this happen too many times.
By the way, me likey the new front.
Old Jan 4, 2008 | 09:02 AM
marcuskeeler's Avatar
marcuskeeler
Disconnecting or running with a dead plug pack is only going to wash your cylinder with unburnt petrol - BAD ! The back firing is when the unburnt fuel builds up enough to weep into the exhaust and get ignited by the other cylinders exhaust pulses, also bad for the sensors and mufflers.
Side jobs or no side jobs, you need to get that off the road ASAP.
Old Jan 4, 2008 | 09:08 AM
pascal's Avatar
pascal
Morning Marcus...
I miss the old carburetor and distributor (no points though) sometimes.
You would think that the days of backfiring are gone.
Hope he finds a solution quick. He hasn't reallyenjoyed that car since August![8D]
Old Jan 4, 2008 | 09:25 AM
RED121572's Avatar
RED121572
On a Grand National I had, the coil pack went bad. When the car would reach about five pds of boost, the car would hesitate and then back fire out through the airfilter.
A bad coil pack on your car is what I would guess, too. Good luck!
Old Jan 4, 2008 | 10:06 AM
marcuskeeler
Ah yes,I fondly remember twisting the distributor round to try to optimise the spark angle. Clockwise until it pings then back a couple of degrees, repeat as required.
It's not the best workaround BRENDEND, but you could pull the injector plug off the offending cylinder, it'll stop the fuel going in so no backfiring.
Old Jan 4, 2008 | 10:54 AM
brendend's Avatar
brendend
ORIGINAL: marcuskeeler
im stopping by ford today to see if they can fix it today. if not ill do that marcus.
pascal i disconnected to battery when it first started to happen to try and reset the computer but that didnt do it. i dont know what they did since the repaires were done about 1500 miles away. i love the green on our fronts... looks amazing.
Old Jan 4, 2008 | 11:02 AM
brendend's Avatar
brendend
to disconnect the injector i pull the plug above the coil pack plug right?
musnicki
Sep 23, 2015 07:11 AM
spamedic
Sep 9, 2015 12:15 AM
cbird1177711
Sep 2, 2015 04:12 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
