Torque converter install
Old Sep 2, 2015 | 04:05 PM
spamedic's Avatar
spamedic
Default Torque converter install
Did not remove torque converter and can not get it back in. Drops past both splines but lacks 1/2" of being far enough, seems it's not going past the flat spots on converter snout.
Old Sep 4, 2015 | 09:07 AM
spamedic's Avatar
spamedic
Voila! Pump shaft was sticking out too far would not go in so i loosened pump bolts, shaft fell in place, then converter!
Old Sep 9, 2015 | 12:15 AM
tx_zstang's Avatar
tx_zstang
Typically you have to wiggle it in and get it past 3 steps, not 2; the last one seems to be the trickiest. Should not have to do anything with the pump..unless you don't get it all the way in then the pump will get destroyed.
kdryan
Aug 21, 2015 04:01 PM
WDScott
Aug 17, 2015 06:38 AM
ccwebb
Aug 11, 2015 06:47 PM
pjrolvrz
Aug 10, 2015 02:10 PM
dfw692
Aug 7, 2015 11:53 PM
