Any experience w/this alum driveshaft?
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
Would like to take advantage of the good information from this forum and ask any opinions on this particular driveshaft OR your suggestion on a Alum driveshaft. Been debating strongly about this being my next mod but wonder if the upgrade is really worth $500+.
Thanks in advance for your replies.
RE: Any experience w/this alum driveshaft?
looks pretty sweet, i like the 3.5" diameter. I have the spydershaft, bought it mainly because of the great reviews on here, and it is awesome, no new NVH...Ron (the distributor) is also a forum member and helps out as much as possible.
check it out http://www.leonardracingproducts.com/drive01.php
I was wondering aboutthe same shaft myself. I would gowith the spyder shaft but I am lowered and Want a 3.5" instead ofa 4" like the spyder. I would like the extra clearance. By the write up it sounds good. But you knowits easy tojust say its great, come buy it....Maybe someone with one will respond.
I have the Spydershaft as well and its great but now I'm afraid I won't be able to lower it. I just want to put on Roush rear springs which is not too big a drop. Anyone no if this would work without the driveshaft hitting on bumps.
ORIGINAL: wingman75
You'll see that the spydershaft is actually higher than the exhaust h-pipe, so unless you're scraping your pipe over bumps already I doubt you'll have much of a problem. I may be wrong so if you have any first hand experience please feel free to correct me.
