Problem with lowering kit
Old Jan 8, 2008 | 12:10 AM
Stangula's Avatar
Stangula
Default Problem with lowering kit
I lowered my 07 GT the front is level but in the back the drivers side rides 1/4in higherhan pass side does anyone know how to fix this i did it my self so im wondering if i screwed up
Old Jan 8, 2008 | 12:24 AM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Problem with lowering kit
its normal
Scotte28516's Avatar
Scotte28516
Is the pig of the spring(cut end) in the notch of the spring cup and the lower rubber bushings? Not having the pigs in the notches will offset the spring heights and make it sit uneven.
Old Jan 8, 2008 | 06:12 AM
joemagna's Avatar
joemagna
Mine is the same, I hear its normal.
Old Jan 8, 2008 | 09:30 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Scotte28516
Mine does not have notches for the pigs?
Nore does mine have these rubber bushings you seem to mention?
Fill your saddle bags up fully with gas and then check see.
Old Jan 8, 2008 | 09:31 AM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: Stangula
When you measured it, was anybody sitting in the driver's seat?
Norm
Old Jan 8, 2008 | 09:52 AM
NickSezz's Avatar
NickSezz
The gas tank has two separate sides and one could be filled more then the other....I think.
Old Jan 8, 2008 | 10:10 AM
06Redfire3V's Avatar
06Redfire3V
What lowering kit did you go with?
Old Jan 8, 2008 | 06:50 PM
Stangula's Avatar
Stangula
it is the frpp kit i talked to a friend and he said lift the car again and give the spring a quarter turn and i will have to do this a couple time till its right noone was in the car but the rubber bushing on that side was a little warped from the stock spring so that may be it I will lift the car again a try getting the rubber bushing to sit better or replace it I will also fill it full of fuel thanks everyone
Old Jan 8, 2008 | 07:33 PM
Boozshey's Avatar
Boozshey
Mustangs have always looked like that.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
squishbang
Sep 7, 2015 07:57 PM
Tyoung68
Aug 25, 2015 04:31 AM
inyadreems
Aug 21, 2015 09:10 AM
