24mm or 40mm offset?
Old Feb 15, 2008 | 06:18 PM
  #21
Larmo's Avatar
Larmo
Default RE: 24mm or 40mm offset?
Would it hurt to run 24 offset in the back (for an aggressive wider stance) and 40 offset up front (to keep the rubber inside the fender and limit road grime thrown on the side of the car)?? Any drawbacks to different offsets front and back??
Old Mar 15, 2008 | 08:53 PM
  #22
Larmo's Avatar
Larmo
anyone?
24 offset out back and 40 offset up front?
Old Mar 15, 2008 | 08:58 PM
  #23
Andretti's Avatar
Andretti
I cant imagine a problem unless you will want to do a four tire rotation all around, because obviously that wont work....
But other than that, I dont see any problems....
Old May 20, 2011 | 11:47 PM
  #24
starbai's Avatar
starbai
Just curious, does anyone know if the 40mm 20x9's would clear the Brembo's Pkg 2011+ cars?
Old May 21, 2011 | 08:02 PM
  #25
Hack Job's Avatar
Hack Job
I also have a question. I've got 20X9 Razors & my 255/35 tires stick out from the fender 1/4 or so. That would mean I've got the 24mm offset, correct?
I was planning on lowering the car (FRRP K springs) and maybe also going a little wider with the tires as well. Think i'll be ok with that setup?
Thanks.
Old May 21, 2011 | 10:21 PM
  #26
starbai's Avatar
starbai
well i am on sportline springs and therefore a bit lower... with no rubbing at all and that same 20x9 +24 offset.
Theres room to go a little bit wider but I dont think i'd do anything bigger than 275... perhaps if you get an adjustable panhard bar you can adjust the center of the rear axle a bit so that you wont rub.
I really dont think you'll have a problem with 275's though... figure u'll be about 10mm closer tip of tire to fender. it'll stick out a bit more but i really dont think you'll have any rubbing issues.
Old May 22, 2011 | 10:09 AM
  #27
CutterWolf's Avatar
CutterWolf
NO they will not clear them. You have to get the 24mm off set on the fronts to clear big brakes. If I were you I would get 24mm on the front and 40mm on the back.
Old May 22, 2011 | 02:44 PM
  #28
Hack Job's Avatar
Hack Job
Ok, thanks. Now I have more questions. With the 20x9's 24mm, and K springs what's the widest tire I could use? And would it look weird to have wider tires in the back if all 4 rims are the same size?
Old May 22, 2011 | 03:14 PM
  #29
CutterWolf's Avatar
CutterWolf
255's front 265's rear will work
Old May 22, 2011 | 04:13 PM
  #30
starbai's Avatar
starbai
agreed
