Lowered cars - Caster/Camber Plates
Guys and Gals, those of you who have lowered your cars and upgraded th front shocks, did you have to install caster/camber plates? Also, did anyone have allignment issues after the install?
Thanks,
Apex
Thanks,
Apex
RE: Lowered cars - Caster/Camber Plates
No, most just need the camber bolts ($40) which give you enough of an adjustment. You should always get an alignment after a drop (or lift for that matter).
ORIGINAL: Aziraphale
You can get them a lot of places but if you're ordering things from bmr, they have them.
http://www.bmrfabrication.com/2005MustangSUSPENSION.htm
Just under the lowering springs about 3/4 the way down the page.
Mine were still in factory specs when I took it in for an alignment after the drop..
they said I didnt need anything..
Maybe they were too lazy to care.. I duno..
but it seems fine as it is.
I did install HD Camber plates - I like the adjustability and rock solid strut mounts. When you see the OEM strut mounts you'll know what I mean. But they are not required. Correct me if I'm wrong guys but don't you need to elongate one of the strut to spindle attachment holes in order to use the adjustable camber bolts? To me it seems like kind of a half baked solution, it apparently works just fine though.
ORIGINAL: Fred Malibu
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
